"Fault in communication with Vehicle ECU"
Still trying to figure out why my 05 Super V8 sometimes pops into neutral when kicked down at highway speeds. I've been using my iCarsoft reader to get the codes and clear them so I can see the errors each time. The common thread seems to be communication between the ECM and the other modules in the car. I get U2523 "CAN message timeout" from at least 4 different modules and P1797 "CAN Transmission Control Module to ECM malfunction" This all seems to point to a connection problem at the ECM.
Strangely the iCarsoft reader can't seem to talk to the ECM either. When I stop on that module I get a message on the reader that says " Fault in communication with vehicle ECU" and I can't see the status of the ECM or any error codes.
Battery is new
Headlight grounds have been cleaned
Transmission connector is dry
Coils and plugs are fresh within a year
No ABS sensor errors are posted
All other aspects of the car work perfectly
It seems like I should check the connector on the ECM and clean it out with some contact cleaner.
Any other knowledge or suggestions on the subject?
Much Thanks
Jeff
Battery is new
Much Thanks
Jeff
Battery is new
Much Thanks
Jeff
Battery is new
Much Thanks
Jeff
Jagman1984
35
05-22-2019 05:41 AM
harryc
04-24-2012 01:42 PM
