Fault Flashes from pasenger air bag
Hi All,
I have a 2004 4.2 ltr S Type V8 SE which I have owned for 3 years and been very pleased with, it has only done 29,000 miles ( being an import from Japan) . I now get the permanent pasenger air bag fault showing.
Together with this I have the small blue light flashing, it flashes 4 times and then goes of for a shortish time and then flashes four more times again, this four flashes and off for a short time continues permanently.
I have seen some tables showing different flash sequencies that indicate what the fault might be , but I haven't seen any thing indicating what just 4 repeated flashes mean. Can any one point me in the right direction ?
User 42324 (06-21-2024)
OK, understood :-)
Do you have the possibility of reading DTCs? As motorcarman already indicates, it might give you more information.
Best regards,
Thomas
Replace the sensor ?
HI motorcarman & Thomas,
Thank you very much for your replies, motorcarman for identifing my flash code 44 fault and with quick reference diagnostic guide showing it to be a Passenger side impact sensor -27.
Yes Thomas as you can see I was able to print out the diagnostic guide, a very useful reference.
With reference to the impact sensor, I am sure that my car has never received any side impact so suspecting the sensor or related connections could any one point me in that direction of findind it.?
and -27 ?
Is it worth getting some one to 0DB scan my car and tryi to reset the fault ?
Thanks again for both of your help.
DennisJohn
and -27 ?
DennisJohn
Quote: "Is it worth getting some one to 0DB scan..." Unquote
That's what I meant when asking whether you have the possibility of reading DTCs, not whether you were able to print the diagnostic quide.
Sorry if I wasn't clear.
And yes, for me that would always be the first thing to do, doing an OBD scan of the car.
Best regards,
Thomas
Best regards,
Thomas
superfisch
05-02-2022 02:29 PM
benwhitehouse
07-22-2013 05:19 PM
steffenvh
01-10-2010 11:45 PM
kandaonly
11-03-2008 05:25 AM
