Fault lights
Fault lights
Has any one gotten fault lights from temperature changes? I have gotten 2 fault light when the temperature gets below freezing. So far it has been a parking brake fault and suspension fault. It only seems to happen under freezing. I park the car in my garage and in the morning no faults. The garage stays about 50 degrees. If I leave work and its below 32 I get a suspension fault. I left work the other day and it was 34 degrees out and no problems. I'm about 99% sure the bags aren't leaking. I took it to my mechanic the first time and the the code reported a leak.
I do think there is a good possibility of this being the fault. I will have to get the battery tested. One of the codes flagged was low voltage. I figured it was from me installing new subs and configuring the audio system with the car not running. I have noticed that my battery maintainer does come on when I just open the trunk. I don't think the battery should drop low enough for the charger to turn on from just a couple lights.
Mugatu
22
06-23-2020 01:50 PM
OkieTim
09-08-2015 04:48 PM
