A few lingering issues after some service
Old 07-29-2020, 03:54 AM
JagV8's Avatar
Received 4,564 Likes on 3,968 Posts
Originally Posted by EuroCollector
I found my BT ELM adapter and fired up the Torque app. I found out so far that the car won't go into closed loop due to 'low temp'. Coolant temp? That's fine. O2 heater temp? Maybe.
Was there a code? Never seen such a message before...
Also noticed that the primary O2s won't give out any readings. The rears go between 0V and 0.05V.
Sounds like the tool fails to cope with the front O2s. Note: they are not voltage-based (I don't see what actual MY etc this car is, however).
Old 07-29-2020, 07:11 AM
EuroCollector's Avatar
This was a message for why the car won't go into readiness. Says low temp. Can't be coolant temp, as it's reading fine via OBD
The car is a 2004. That would explain why I don't see voltage in the PID for the front O2s then. The tool might not be able to read them for sure. I just have a hard time believing that both front O2 heaters went at once.
Old 07-29-2020, 09:49 AM
arctic_man's Avatar
Here is the readiness guide for the o2 sensors.
Here is what triggers a P1646 and P1647.
If you need some of that additional info, I can track it down. I hope this helps.
Old 07-29-2020, 10:32 AM
Thanks! I actually did not do the O2 drive cycle. I did do the one that's supposed to get all of the readiness tests, though. It only succeeded in setting the Misfire and one other that I can't recall at the moment.
I'll post another update soon...
smoggyx100
08-22-2021 04:01 AM
Racer X
08-03-2015 11:35 AM
sirsws
11-06-2013 01:51 PM
mgb4tim
06-09-2012 06:59 PM
aradapilot
10-19-2009 07:37 AM
Quick Reply: A few lingering issues after some service
