Flex disc (donut) replacement
Hi all,
After owning my 05 Xj 4.2 LWB for around one year, I am considering replacing the flex discs for the prop shaft. I understand that the S type flex disc fits, and I also heard that some Ford cars use the same parts as ours.
Would anyone provide the part number of Ford for the flex disc? Thank you!
As a former Lincoln LS owner I can tell you Ford only sells the complete driveshaft.
Why are you replacing it?
You can look here for other makes
Flex Disc - p - AutocarSpare
Or here
Product Search Drive Couplings - IMS
I found these when I was looking for a center bearing for the LS (which I finally found at MotorCraft)
Or here
swoop22
10-31-2011 03:19 PM
cincinnati
10-31-2011 03:12 PM
