flexi pipe leaking on 2006 xj6tdvi
Something like this might be the best option - Not that I have a Diesel but there was a comprehensive write up of this repair in the May 2016 copy of the JEC magazine and this appears to the be the same parts as used by David Marks.
JAGUAR X350 2.7 DIESEL EXHAUST CATALYTIC CONVERTOR REPAIR KIT | eBay
Hope that helps.
Hope that helps.
Received 9,011 Likes
I had a chat with XJK Jaguar on this subject the other week, even though my car is a petrol. There are two types of repair section, (1) aftermarket with no flexible section - cheapest, and (2) the Jaguar one, with the flexible section.
I was told they get people in who've fitted the non-flexible kit and are complaining of vibration ! So Jaguar would seem to be right in the original and the repair section having the flexible section. Of course the Jaguar part is the most costly, so if one can put up with a bit of vibration fit the rigid pipe kit !
At the X350 Seminar last month he showed some photos of failures and showed where they had failed at the flexible section, hence his recommendation for the non-flexible repair sections.
As I recall previous postings in this forum some people have found the non-flex units fine, and some have had vibration problems. I suspect it's to do with how they are aligned before they are tightened.
Personally I'd go for the flexible ones.
SimonXJ (06-15-2016)
jerryl440
06-25-2016 12:17 PM
