Fluids Needed
I have purchased a used 2005 Vanden Plas and am researching the fluid types and quantities to use. Is the below information correct?
2005 Jaguar Vanden Plas with 4.2L V8 - Naturally Aspirated
- Engine Oil for X350 4.2L Naturally Aspirated Engine: 5x30 Mobile 1 European Car Formula 6.3 qt
- Transmission Fluid for ZF 6HP26 : Lifeguard 6 , (Ford Motorcraft Mercon SP and Shell Spirax S4 ATF MSP are identical to Lifeguard 6). For drain and fill, you need 5.5 liters / 5.8 quarts. For complete flush, you need 9.5 liters / 10 quarts.
- Brake Fluid: Shell DOT4 ESL or a low viscosity DOT4 brake fluid that meets ISO 4925 class 6 requirements.
- Power Steering Fluid: DEXRON III.
- Antifreeze: DexCool
From my notes for my 2007 Jaguar XJ8
Engine: 4.2 Liter V8 Quad Cam AJ34
Gearbox: ZF6HP26
Final Drive: Gen 2 - not LSD
Here's what I use (capacities are approximate):
Coolant
OEM Spec: WSS M97B44 Extended Life Coolant. (ORANGE)
Used: Peak OET European Coolant (PINK) after thorough flush
Capacity: 14 US Quarts
Engine Oil
OEM Spec: Castrol 5W-30 to Jaguar specification WSS M2C913 - A or B.
Oil specification -API SL/EC and ILSAC GF-3
Used: Mobil 1 5W/30 Synthetic or Castrol Edge
Capacity: 7.4 qts including filter
Power steering:
OEM Spec: Dexron III
Used: Mobil 1 Synthetic ATF
Transmission Fluid
OEM Spec: ZF
Used: ZF Kit
Final drive:
OEM Spec: 75W-140 M2C192A
Used: Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant
Capacity: 1.25 US Quarts
Brake Fluids:
OEM Spec: DOT 4 ISO 4925 Class 6
Used: Bosch ESI6
Capacity: 1.5 US Quarts for full flush
HTH, Dave
Gearbox: ZF6HP26
Coolant
Engine Oil
Power steering:
Transmission Fluid
OEM Spec: ZF
Used: ZF Kit
Final drive:
Brake Fluids:
Used: Bosch ESI6
HTH, Dave
rsa760041 (01-15-2024)
Gearbox: ZF6HP26
Coolant
Engine Oil
Power steering:
Transmission Fluid
OEM Spec: ZF
Used: ZF Kit
Final drive:
Brake Fluids:
Used: Bosch ESI6
HTH, Dave
Gearbox: ZF6HP26
Coolant
Engine Oil
Power steering:
Transmission Fluid
OEM Spec: ZF
Used: ZF Kit
Final drive:
Brake Fluids:
Used: Bosch ESI6
HTH, Dave
kchirume
08-10-2013 01:22 PM
