Flywheel?
Flywheel?
I'm working on a P0171 issue, lean bank 1. It seems impossible to get a clear answer to which side of the car is bank 1. I thought I knew, but the more I search for a definitive answer the more I'm uncertain.
The JTS says, "References to Bank-1 and Bank-2 are made with regard to the engine. When viewed from the flywheel the right-hand bank will be Bank-1 and the left-hand bank will be Bank-2." Well, I guess you have to know what they're referring to by flywheel. LOL
I've also read that bank 1 refers to the side with cylinder 1, which for the x350 appears to be the left hand side if I'm standing in front of the car.
All I need is a simple answer - if I'm standing in front of the car, which side is bank 1? Thanks, anyone ... do I feel stupid or what ...
Received 12,952 Likes
Hi kbeachy,
Here's the chart from one of the Jaguar Vehicle Specifications books. The diagram on the right applies to the X350:
So if you are standing at the front of the car looking at the engine, Bank 1 is on your left, and cylinder 1 is closest to you.
P.S. For the record, if your car has an automatic transmission, it doesn't even have a flywheel. Instead, it has a "Drive Plate" or "Flex Plate."
Cheers,
Don
Cheers,
Don
kbeachy (05-13-2017)
Hi kbeachy,
Cheers,
Don
Cheers,
Don
