Found a cheaper answer to transmission fluid
This is from the mobil 1 Site and says you can use it in place,so I might give it a try.
The synthetic base oil enables excellent performance even in the severest of operating conditions. It offers outstanding gear shifting and power transfer performance versus conventional ATF fluids. The inherently high viscosity index and stability of Mobil 1 Synthetic ATF help protect against thermal breakdown at high operating temperatures, while still providing outstanding performance at very low ambient temperatures.
Mobil 1 Synthetic ATF combines high-performance synthetic hydrocarbon base oils and a superior balanced additive system to provide significantly higher levels of performance above conventional fluids. This unique, advanced technology provides long drain capability, excellent friction retention, and low-temperature fluidity. Further, it helps to improve overall transmission durability and cleanliness. Mobil 1 Synthetic ATF is also compatible with conventional ATFs.
Mobil 1 Synthetic ATF is formulated for use in most North American, European and Asian vehicles.
Approved for Allison C-4 applications
Exceeds JASO 1-A performance standard
Also suitable for use in vehicles that specify the following fluid requirements:
Audi G 052 025-A2, G 052 162-A1
BMW LA2634
Esso LT 71141
ETL-7045E, ETL-8072B, N402
Ford* MERCON*, MERCON V, MERCON LV
All 2005 and earlier GM vehicles**
Honda ATF-Z1*
Hyundai SP-II, SP-III
Idemitsu K17
JWS 3309
Kia SP-II, SP-III
MAN 339F, V1, V2, Z1, Z2, Z3
Mazda ATF-III, ATF-MV
Mercedes-Benz 236.1, 236.2, 236.5, 236.6, 236.7, 236.9
Mitsubishi Diamond SP-II, SP-III
Nissan Matic-D, Matic-J, Matic-K
Subaru ATF
Toyota T-III, T-IV
Voith 55.6335.XX (G607, G1363)
Volvo 97340
ZF TE-ML 03D, 04D, 09, 14A, 14B, 16L, 17C
* Not recommend for CVT applications, MerconŽ SP, Ford Type F
** Mobil DEXRON-VI ATF is recommended for 2006 and newer GM vehicles and improved performance in 2005 and earlier vehicles, wherever DEXRON is specified.
Automatic transmissions should be checked for proper fluid levels at regular intervals, and the fluid should be changed at manufacturer-recommended intervals. However, this may vary due to your vehicle's operating conditions. Some manufacturers recommend more frequent changes of transmission fluid under severe driving conditions, such as heavy traffic, hot weather and trailer pulling.
BMW LA2634
Esso LT 71141
Honda ATF-Z1*
Idemitsu K17
JWS 3309
Kia SP-II, SP-III
Subaru ATF
Toyota T-III, T-IV
Volvo 97340
Howdy Folks!!...
I'm gettin' ready to change my fluid, and check out this O'Reilly website. It shows that Pentosin can be used in even the new Jags...
Pentosin ATF1-1L - Automatic Transmission Fluid | O'Reilly Auto Parts Click on the "Compatibility" tab for list of vehicles.
Only $14.95 in my neck o' th' Woods...
Drive On!!...
Fast Freddie...
Drive On!!...
Fast Freddie...
The ZF Lifeguard6 fluid is $17, I can't imagine using a substitute in this case. The last literature I read from ZF clearly states that there is no equal fluid. This old thread is full of guesswork and supposition, there is no longer need to wish, guess and hope, you can have the right stuff reasonably.
There is a new Febi- Bilstein oil that also meets the Shell M1375.4 spec for $11.
BMW ZF Automatic Transmission Fluid (1 Liter) 83222220445 (83-22-2-220-445)
They charge $22 for the ZF brand.
I had my transmission specialist do the service on the ZF in my car
He said he uses a ford product said the ZF stuff would probably last longer though but I get my transmissions serviced every 40,000 k,s regardless of what the dealer says
should be fine
On the other side of the coin I went with my wife's Jeep and used ATF fluid in the transfer case as this is what all the sites at the time recommended
The transfer case was destroyed after 60,000 k,s indie said he had never seen one gone like that the shafts have a Teflon coating looks like it got so hot the Teflon coating melted and blocked the oil gallery's hence new transfer case
Needless to say on the Jeep forum I am a senior member of the other guys using ATF fluid doing it themselves till I had that problem difference with the other guys they hadn't done the mileage I did in such a short time otherwise they probably would have had problems as well since then all oil sites now say refer to dealer for transfer case oil
Ever the inquisitive type we have now found out that Mobil make the original oil and Mobil call it 424
Moral of the storey if you are not sure even though the internet say yes
Do your home work
I don't know in other places in the world but its about 7 grand for a re-con ZF over here and only one company I would trust to do it that's why I get it serviced every 40,000 k,s
should be fine
Do your home work
#28
Good to know. I was going to do a complete flush when changing the filter until I saw the fluid cost, also considering I have to buy a new pan and sleeve too. ZF seems to only recommend the trans fill and not a flush anyway.
OkieTim
09-08-2015 04:48 PM
carcycle
09-07-2015 10:22 AM
Wes Steenrod
09-06-2015 06:52 PM
