Freon Leaking Around the Valve of Compressor
96 XJ6 VDP. Freon seems gone so I try to charge it.
When I charge it I found freon leaking and compressor oil with leak detector coming off the "valve" of the compressor. I though it is pressure regulator but not sure. Captured video here.
Any suggestions for this issue? Compressor seems working fine as long as the freon is still circulating before it is gone (take several hours down to the pressure the compressor will not kicks in.
If I think I know what I am looking at I would say the schrader valve has gone.
So long as you know the size they can be extracted with a special tool and replaced.
Needs to be done quickly to minimize impact of moisture so a day with low humidity is best choice unless you have specialized equipment.
Good luck.
Ah ... now you may well find there is greater exprerience for this problem in the X300 sub-forum which covers your model; this sub-forum is 2003-08 models.
Moderator ?
Moderator ?
slownlo
04-09-2016 07:31 PM
