Front Air Strut Cut-Away
#41
The shock study and fix I did on my xjr x358
The green graph is the Comfort setting of the front, dark blue is sport setting and the tur quise is the rear at sport (closed bypass)
One of my front was stuck in open bypass (comfort)
Ole Mobeck
Facebook Post
Ole Mobeck
Don B (11-06-2017)
#42
Reyes still there?
First compliments on the photography! Most helpful
My question:
My 2004 XJR has problems on the front suspension. Both were replaced with used ones. Now I think they have put comfort suspensions (C2C41347) instead of sport (C2C 41352) on my cat.
What is the difference between the comfort and the sport struds? and how can I see the difference from the outside?
Rob, from the Netherlands
My question:
#43
Rob, the sport units has a red dot on the top of the strut, on the black tin tank.
The Comfort has a green dot. Se in my Picture its red. There is also a white Version witch I think is so called universal replacement but I am not shure.
The difference is that the sport Version has a smaller air Chamber and is threfore more progressive as a airspring, lets say it acts like a stiffer spring.
The green has a laarger air Chamber in each shock.
Ole M
Ole M
Don B (11-08-2017)
#44
Ole M
Ole M
#45
Reyes still there?
My question:
My question:
PS I thought before that evident difference only in rear air bag size and fronts are the same. Am I wrong?
#46
#47
#48
So to reiterate that? I believe that the Body of the car Is in the way for the valve to actually come out all the way. I'm pretty sure that if I drop the shock the valve will come out but is there way to put it back in to make it stay without it popping back out under pressure of bumps and potholes
#49
Received 12,932 Likes
Welcome to the Jaguar Forums! It's great to have you with us.
The air line connects to the pressure-retaining valve via a compression ferrule or "olive" and nut. Is it your pressure-retaining valve (PRV) that has come loose from the air spring/shock absorber? If so, it may need to be threaded back into the air spring top plate. See this thread for information about the system and links to helpful documents:
Jaguar X350 Air Suspension & ECATS System Summary: Components & Operation
It might help us help you if you could post a photo or two to illustrate the problem.
In the meantime, please also visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
#50
Thanks to Reyes for his work.
I’ve been working on my sons X358, complete rear subframe rebuild on second hand subframe, blasted and painted, all new arms, bolts, handbrake motor, cables, stabilisers etc. Tank and prop shaft out and new front to back and over axle brake pipes (jaguar parts as recommended by member on subframe removal topic, very reasonably priced!). The complete subframe was in a very poor condition, rust and all bushes shot (not unusual apparently), poor for an 11 year old car and 99K miles. We have dismantled the struts as far as we can and they are rusty too, including where the air bag runs. I always like to know what’s going on inside parts and Reyes’s photos are just the job, will post some photos in a new thread, if that’s appropriate.
Bob
Bob
Mugatu
22
06-23-2020 01:50 PM
34by151
09-06-2015 05:14 PM
