Front Air Strut Plug Cracked- Need a Replacement
The electrical plug that connects the two wires to the top of the front air strut is cracked. I would would like to replace it with a new or non-broken plug. I have searched the world over for a part number and can find nothing. Last summer I ran into a similar situation with a disintegrated plug on back of the throttle body and was able to trace it back to Ford.plug/pigtail. I would greatly appreciate any assistance in sourcing one.
Don B (01-08-2020)
Unfortunately the information JLR provide for Ford-era cars is limited. The best I could find was the equivalent from the later/current XJ X351. Can you check the attached document to see if the connector matches what you need? If so, it is available to buy as YPC802170. Pigtails are 41841145 if needed. Britcar sell both.
Don B (01-08-2020)
I have a different issue. My passengers side front strut seems to be in “hard” mode. Slow bumps is fine. Smooth as butter. A little faster and it acts like it is a solid.
I have driven in hard default due to leaking air or failing compressor. But that was lowered. This is normal XJR ride height, lower than XJ. But have a sport RMT rebuild in parts pile.
Installing to see if it is a damper failure. No codes on my iCarsolf or a friends expensive scanner. His can set ride height.
megacattin
03-11-2019 03:06 PM
baldeagle15
11-03-2012 08:50 PM
