Front lights re/re
Old 05-12-2019 | 03:37 PM
Peterinio's Avatar
Default Front lights re/re
Hi. Could use a bit of assistance on the front lights. Not the headlights. There are four light units with the headlights being on the outside. The ones on the inside are where I am stuck and the manual isn't much help.
Each of the units has two lights inside with one in the middle and the other at the very top of the unit. The rights side middle light went out but the bulb is fine and I am unable to locate a fuse for it. Resistance test on the bulb and connection show ok so maybe not a fuse issue. I decided to take the left side bulb out and now it doesn't work. I also can't figure out how to reinstall the spring retainer clip. Does the whole light assembly come out to be serviced?
Appreciate any guidance. Thanks. Peter
Old 05-12-2019 | 10:20 PM
motorcarman's Avatar
The smaller lights in the MAIN BEAM light assy are called PILOT LAMPS.
They are your front sidelamps or PARK LIGHTS when the headlamp switch is turned to the sidelights position.
The MAIN BEAM lamps (center) are just that. MAIN BEAMS.
bob
Old 05-12-2019 | 10:25 PM
Peterinio's Avatar
Thank you Bob. Now I just need to figure out how to get them to work again. Peter
annamiata
12-08-2019 03:56 PM
ericindy
04-13-2014 06:51 PM
charger12
04-04-2012 05:23 PM
BillyRay59
04-04-2012 08:54 AM
Quick Reply: Front lights re/re
