Front suspension upper control arm HEX nut
Hello all,
On "Bilstein"'s video below, at 03:29 - narrator emphasized to "Disconnect the ball joint from the upper control arm, the nut must not be used again".
1. Why?
2. What is the size/dimensions of this HEX flunged locking nut need to be replaced on the front suspension upper, (wishbobe) control arm?
A. Does it metric/Inch?
B. What is the nut wall height?
C. What is the thread coarse pitch?
D. Does nut require the "Nylock Lock Nut" mechanism on top?
(https://www.nutbolt.org/Datasheets/Nut_HexThin_M.pdf)
(That's because "Lamförder" C2C41961 & C2C41960 does not include these special nuts w/control arms)
Thanks.
1. Why?
Thanks.
Can't use current upper control arm locking nut with a spring washer, (https://media.rs-online.com/t_large/F0530876-01.jpg)
and flat stainless steel washer beneath?, (https://www.masonryfixings.ie/image/...-1-500x500.jpg)
(Sure have to choose both washers correct width in order to remain ~1.5-2 free coarse threads at the vertical ball joint bottom)
In order to allow me replace the front air suspension/shock absorbers, I need to release some other hex, flunge
locking nuts from other arms, (like: front stabilizer bar link, front lower arm etc. https://simplecircuitdiagram.me/wp-c...ng-library.jpg),
Soooo... do I need to replace every single releasing flunge locking nut from every arm, (as all are nyloc nuts type)?
KittyVet
05-31-2020 11:57 AM
ANIMAL JAGUAR
Diesel variants - All models
11-14-2019 03:06 AM
sweatyfox
01-19-2017 01:10 PM
