Front Sway Arm Nut Size
04 XJR Vin Range: G00442 - G45703
After installing a new front air shock last night, I was going to put the sway arm nut back on as the last step before putting on the tire. Jumpin Jehoshaphat, no nut! Since I have to make a hardware store run this morning, I thought that I would just pick up another one. Not easy to get the specs. As I walked into the garage, I found the little bugger.
For future reference, here are the specs:Flanged nylon lock nut M-10 x 1.5 with a 15mm head.
The following 2 users liked this post by luv2fly:
04Xjrsteve (06-10-2024),
Wingrider (06-11-2024)
gbmarc
05-14-2023 06:22 AM
G.M. Webster
07-13-2022 09:11 AM
