Front upper A-Arm removal
I was installing a set of Arnott air shocks on the front of my 2004 XJ8 (left hand drive). The upper ball joints had a bit of play. So I tried to remove them.
Working on the passenger side first, I removed the front side bolt (nut is removed from near the ABS module). I could not figure a way to get a wrench on the rear bolt off (nut is near the cabin air filter plenum). Is their a trick to removing this bolt? I did not check the driver's side but I'm assuming the nut near the brake master cylinder is also difficult to access.
Anthony8858
07-24-2016 08:51 PM
