Frustrated beyond belief
Ok guys, a while back I tried to install the Jaguar BT module in the trunk. Didn’t work and I pulled it. Then all 4 door speakers went out. I just ordered a salvage amp because I thought that was the problem maybe I blew a channel and installed it. Much to my surprise and dismay it not only didn’t correct the door speaker issue my Jaguar screen is now in Japanese. UGH..
Any thoughts?
Thanks,
Brian
Any thoughts?
Thanks,
Brian
Xjrdrifter (05-23-2024)
Ps….the amp I replaced it with was the same part number
Any thoughts?
Thanks,
Brian
Any thoughts?
Thanks,
Brian
If you have the Alpine speakers then there is a very good chance they have been dying one by one and you have only noticed when the last one has failed. Pop a door card off and check the speaker for continuity, the wires corrode where they are in the melted plastic. You will see what I mean when you take one off. With your multimeter set on continuity put the probes on the pins in the connector, if you get a beep then you have a different problem, no beep then one or both wires have a break in them. You can solder a link wire in but the wire is usually that dirty the solder wont stick. A couple of mine look like a blind man with the shakes did them, but they do work.
Jaroslav Záruba (05-29-2024)
I checked the speakers out in the door. I took speakers out. Everything looks great no corrosion no nothing. Looks like a new speaker. I don’t know.
eliotb (05-24-2024)
Brian M Williams (05-26-2024)
Just a generic Youtube video of someone checking a speaker with a digital multimeter.
You don't need to spend big bucks on a test meter, just get a cheap and cheerful meter from a car parts store, electrical wholesaler or electronics hobby store.
https://www.youtube.com/watch?v=O6SLf6U7a9A
Jaroslav Záruba (09-26-2024)
i cannot say thank you enough. Bought a voltmeter and they are dead as a door nail. Wow. All 4 at the same time. But I think you had a point that they were going and I didn’t notice until they died.
now…what do I replace them with?
Or if the circuit is broken on the (rather short) exposed part of the wire you could bridge it again.
I had all 4 speakers gone and only one of them could potentially be repaired this way, so I just bought a set of 4 from someone's X-Type.
Jaroslav Záruba (05-30-2024)
samstagmoonyham
23
10-22-2022 05:22 AM
qwiketz
08-04-2011 06:38 PM
