Fuel door
Received 13,104 Likes
Cheers,
Don
I figured out the problem with my fuel door NOT staying closed. Thought I'd post my experience in case someone could benefit: one of the 10 mm nuts which holds the REM (rear electronic module) also holds the fuel filler flap solenoid in position. The particular one on my car was loose, allowing the solenoid to back out of position, which in turn pulled the catch (which is supposed to hold the fuel filler door) just enough so it would not engage on the door. A simple adjustment and tightening of that nut did the trick.
Don B (05-16-2017)
