Fuel Filter Replacement / head rests adj. ?
Anyone know where the fuel filter is located. Does the battery need to be disconnected to change it? I bought a new filter to replace since mine is overdue, but can't seem to locate. I have a repair manual on the way, but I wan't to go ahead and swap it out.
Also, how do you move the front seat headrests up and down?
Thanks.
Thanks.
http://wiki.answers.com/Q/Where_is_t..._on_the_XJ8_V8
Not sure if it's right, but found that on a quick search
Found it, replaced it. Easy job. Like you said right under the left side of the drivers seat. You really don't even have to get under the car to change it out as it is right there on the side facing outward easily accessable by just laying on your side. Took 20 minutes to change. Just carefull as you will get about a cup of fuel coming out when you loosen the nuts. also, loosen at least 3 of those hose holder bolts so that you can get the hoses loose enough to pull the filter.
The following 2 users liked this post by Clifsmith:
Richby30 Apparel Company (09-24-2016),
Xeno (01-07-2017)
X_Type_South_Africa
12-09-2015 05:37 PM
Fraser Mitchell
10-01-2015 04:06 AM
