Fuel Pressure sensor
#41
#44
#45
Stuck
Miss my car. The garage can’t determine why it is misfiring. At this point they feel a slipped timing gear is the only thing they can think of. I really can’t justify the huge expense to do that unless I do it myself. Of course there is no guarantee that that is the problem. Complete mistery.
#46
Going back on JagV8's earlier comment, why still Open Loop after very nearly a minute and revs at 1500 rpm? Is your temperature gauge giving the ECU a false reading? None of your uploads show Engine Coolant temperature?
Also, your Throttle Position (TP) 17.3% - Max I tend to see at idle is 3%? Is your TP sensor U/S?
#47
#48
#49
#50
The PCM just tracks what values it has seen min & max. Min of 17 is fine, max hardly ever gets to 100. It figures out what you want fairly easily.
Something is wrong about the OL, yes. Basically check all the things for plausibility in the hope something's obviously faulty and then life gets tougher.
christophe_autos
General Tech Help
07-09-2014 12:18 PM
