Fuel pump replacement plus "Jet Pump"?
I need to replace my fuel pump in a 2004 VDP XJ8. Looking online I see a fuel pump assembly at Rock Auto made by Delphi at $398 which looks a good price?
I have been told to also replace the "Jet Pump" at the same time but cannot find any jet pump anywhere??
it appears that the jet pump does not come as part of the fuel assembly?
Is there a different name i need to use or does anyone have a part number?
Many thanks for your help.
You are looking at the complete unit numbers.
The numbers i gave you were just for the sending units.
They will tell you how much fuel is in the tank.
Mine were both in need of replacement.
Open circut on both of them, that said the tank was empty.
When it was filled, till it was about half empty.
If your gas gauge is working well.
Just replace the pump for $30, & your done.
Or listen to your Jaguar mechanic, & the dealer.
Its your choice, & your money, good luck to you
djpxk8 (06-17-2023)
JRHJR
01-27-2020 04:53 PM
