Fuel Tank 2005 XJL
Guest
Posts: n/a
The fuel cell was recently replaced on this XJ. Before the unit was replaced, I routinely put 23 plus gallons of fuel in it, however since it was replaced I can only put 20 gallons in it when the gauge reads empty. The dealer advises they installed a new tank with pumps. When I filled the new tankthe gauge only read 3/4 full. I took it back to the shop and they advised the fuel sending units were faulty and were replaced. Now the gauge reads full when the service station pump stops automatically but only 20 gallons is dispensed. Any idea what is going on? Did this car originally have a larger fuel cell? Was the incorrect fuel cell installed? the VIN is 5sg47808
Check your owner's manual. For 2005 the tank capacity is listed as follows:
Normally
Aspirated Supercharged
Tank capacity22.4 US gallons 22.3 US gallons
85 litres 84.5 litres
Fill capacity 20.9 US gallons 20.3 US gallons
79 litres77 litres
Reserve capacity 1.5 US gallons 2.0 US gallons
5.8 litres7.5 litres
My 2004 has a smaller tank 18.7 gallons.
The neck probably held .5 gal for some reason the sensor on the fill nozzle was reading your tank fill wrong. My wifes Mercedes would not shut the nozzle off and it spilled over everytime. Still does occasionally to this date. We now just listen for the noise of the air cavatating out of the neck and stop filling and it's been working for us.
Guest
Posts: n/a
well when i first got my car i had two trips to the dealer where htey did a bunch of little things such as my fuel sending units. I bought my car in Texas and drove it back here to Florida. On the way back on my first tank of gas ever the computer said i had 0 miles to empty yet the gauge read 1/4 tank left, so i just ran it down until the light came on and then totally filled it up and it worked great after that, even before they replaced the sending units. so i think they are being truthful with you and as with any part sometimes they are partially or totally faulty from the factory. As long as it seems to be working now I wouldnt worry about it. the difference between your old fill and new was perhaps it wasnt seperating the reserve and the regular parts of the cell correctly. I think this was the case with my car also.
Guest
Posts: n/a
hen555
09-07-2015 11:13 PM
deanh
09-06-2015 08:20 PM
KarimPA
09-03-2015 07:32 PM
