Fuel Temp Sensor & Coolant Temp Sensor
Received 12,932 Likes
Hi XJ8JR,
According to the '04 New XJ Technical Introduction dealer training manual, it's difficult to tell, but from the scarce information provided the sensors do not appear to be the same part.
The Engine Coolant Temperature Sensor (ECT) receives a 5V supply from the ECM. Its resistance varies proportionally with coolant temperature. At 20 deg. C it will have a nominal resistance of 2.45 Kohms and the voltage across the sensor will be 2.38V.
The Engine Fuel Temperature Sensor (EFT) also receives a 5V supply from the ECM. Its resistance range is 1 to 95 Kohms and the voltage across the sensor ranges from 0.2 - 3.8V. The ECM uses its signal to adjust fuel pump pressure to prevent vaporization and ensure adequate fuel supply to the injectors.
The EPC shows different part numbers for the two sensors, and jaguarmerriamparts.com shows different prices:
Coolant Temp Sensor LNA1600AA $44.07
Fuel Temp Sensor LRA1600BA $42.51
Rock Auto carries the CTS, but does not list the FTS.
My guess is that the sensors are similar, but that their resistance ranges are different. The manual does not say, but it's even possible that the EFT's resistance operates in the opposite direction compared to the ECT, falling with increasing temperature (i.e. it may be a negative temperature coefficient (NTC) thermistor).
You could test them manually with an ohmmeter and a pan of water. Measure their DC resistances at room temperature, then dip the sensor tips in a pan of hot water for several seconds and measure the resistances again and compare the results for both sensors.
Cheers,
Don
XJ8JR (09-29-2014)
cats4.2
07-05-2021 10:55 AM
eddiebear
01-02-2015 02:35 PM
Sogirlish
04-08-2010 02:18 PM
