Fuel Trims
Dear Forum,
My bank I is very well behaved; a few percent (either way) long keeps short at zero.
However, is it okay that my bank 2 has to go (at idle) mostly minus 4-6 % (it varies) sometimes all the way out to - 10 % to keep my short term bank 2 near the zero? I do not get why bank 2 needs to remove so much fuel? I mean, if there was a vacuum leak on bank 2, I would understand the ECM adding fuel to burn it, but what condition would cause the ECM to reduce the fuel so strongly on just one bank?
Unless of course I have completely misunderstood this whole subject?
Everything seems to be running beautifully (especially now I have replaced a failed thermostat)….I mean, please do not misunderstand me, for a normally aspirated V8 this thing really GOES!….Please, should I just calm down and leave it alone?
At idle.
I will post LTFTs at 2,500 revs
EsRay (08-28-2019)
Or have I got this completely wrong?
Best regards, Ray
![Red face](https://www.jaguarforums.com/forum/images/icons/icon11.gif)
IF I UNDERSTAND, what the system is trying to do, is to match both long to short as close as possible to each other, with zero as the ultimate goal for both.![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Squeeze every bit of power from what is burned so nothing is left.
They have it down pretty darn close when all the oxygen is burned, impressive.
Currently, it is indeed reducing fuel. Whether it was doing that in the past I don't know, but it wasn't - at the very instant - if it flagged a lean code.
You'd want the freeze frame data to see that instant's conditions.
You may well now be looking at very different conditions (speed/load/rpm/...).
EsRay (09-01-2019)
Fuel being added to burn unmetered air is easy to sort...Find the vacuum leak. But please, where do you look to see why fuel is being injected and then removed at such a high rate, on one Bank alone?
Unless or perhaps a Fuel Injector is now on its way out in Bank 2....I will try adding an Injector Cleaner....See if anything changes?
Looks like I will just have to wait until whatever it is gets bad enough to flag a code and some freeze frame data?
EsRay (09-01-2019)
EsRay (09-01-2019)
Thanks JagV8; took what you said onboard. Cleaned MAF with my pukka cleaner; Any MAF problems gonna affect both banks, not just Bank 2. Could be part-blocked Cat...Had somewhat higher Bank 2 negatives since bought car.....Think the Injector (number 7) I recently had to replace could have come from Bank 2 (the garage who cleaned and tested them 'juggled' them, so don't know if the 'problem' number 4 injector I had cleaned, ended up at number 7)?
Anyways, it seems to me that Injector(s) in Bank 2 are my most likely culprit! Do not want to afford to replace them all!!
So, I will try some BG44K and then wait until I eventually get a misfire!
Thanks again for your help....
EsRay (09-03-2019)
JagV8, Wingrider,
Might be worth me mentioning that the BG44K has (so far) reduced the bank 2 LTFT back to around minus 6%.
Maybe this is my car's way of telling me that I have already replaced Injector 7 and that the others are tired?
