fuse layout passenger block 2006 XJ8L
Old 11-21-2022 | 09:11 PM
FastEddie02043's Avatar
Default fuse layout passenger block 2006 XJ8L
I do not have an owner's manual for my 2006 XJ8L and would love to have one, but for now wondering if someone could send a picture of the fuse layout of the passenger fuse block, specifically where the seat heater fuse is ? Thanks You,ED
Old 11-21-2022 | 10:01 PM
h2o2steam's Avatar
Hi Ed,
The front seat heater fuse is actually in the rear fuse box located RHS in spare tyre well.
Fuse 47 20 amp.
Just fixed my seat heaters and found it was actually a system relay (R5) that was my issue. If you have lost your high stop brake light and some of your rear light light cluster's operation, then you might have a embedded relay issue instead.
Hope it is the fuse for your sake.....replacing the relay is a real PITA.
FastEddie02043 (11-21-2022)
Old 11-21-2022 | 10:34 PM
Default Thank You, much appreciated
Thank You sir, I do appreciate your quick and helpful response. ED
sogood
11-20-2022 06:48 AM
Svalbard
03-02-2022 04:29 AM
SirJohn
12-24-2016 12:19 AM
obwoodie
12-12-2015 11:01 PM
mrtalkradio
XJ40 ( XJ81 )
02-24-2012 06:36 PM
Quick Reply: fuse layout passenger block 2006 XJ8L
