I am trying to check the 10 Amp fuse that is supposed to be at location 25 in the engine compartment fuse box according to my owner's manual. But that spot is empty. There is no fuse there. When I put in a 10 Amp fuse there is no connector. It just sits in the plastic panel. Anyone else have this problem. Any idea where the fuse that controls the RH front turn signal,RH door mirror signal, front side marker lights (both sides) and sun visor lights is located on this car?
When I replaced the fuse the new one burned out immediately so now I just have to find the short.
The most likely spot for a short would be the sidemarker lamp - the sockets and electrical connectors are known to suffer corrosion from water ingress. To remove the lamp, first try pushing it upward and swinging the lower edge outward. If you can't get it out that way, apply some masking/painter's tape around the lamp and use a plastic pry tool to pry the lamp loose and work it out of the opening in the bumper. You'll then be able to inspect the electrical connector and bulb socket.
