Gas Gauge quit working help!
So it's been a while and I've only run out of gas twice. I had this thread done I thought but went back to look at it is not there, if it shows up, sorry for the repost.
Where should I start? Where are the wires locted that go to the tank? When I replaced one of the rear struts, it seemed to flicker and worked for a day.
Step by step instructions would be great.
There are two tank sensors on my 2004 XJR. each one is located under the rear seat in the saddle style gas tank. Have you gone thru the onboard diagnostics to test how each sensor reads? If the sensors stop reading, you can check it periodically. The sensors have been replaced once each by the two prior owners of my car! And I replaced one myself. The initial problem on my car was that after refueling the sensors did not immediately indicate full, then they would give an orange warning light since they went beyond the normal reading range, after driving some time they would go back to the normal range, but I never trusted the readings until I replace one sending unit. Until you resolve the issue, use the trip setting and get gas every 300 miles!
RyeJag
RyeJag
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Charlene n John
09-28-2015 06:01 AM
