Gas milage 05 xjr
Gas milage 05 xjr
I just got back from 1200+ mile run up to NC and back. The outside temp was 95 degrees + on the run up and a max of 103 degrees on the return trip. The car ran flawlessly and delivered 28.4 MPG on both legs, accordingly to the trip computer.
I did not know the car was capabile of this kind of performance. The speed limit varied between 55 and 75 MPH the whole way and I usually set my cruse control at 5 MPH over the posted limit.
I took a similar run at Christmas and got 27 and change MPG. The only difference back then was Cold weather and I have sense switched to Mobile 1 synthetic in the engine and transmission.
What do you think?
What do you think?
Reletive to computer milage data, I have found the same optimistic error in every car so equiped, regardless of make. It's a small chore to do the calculation by pen and paper, so I just go along with the game. Still-- 28 MPG and change even allowing for the computer fib is empressive.
The thing that really got my attention was the full 1 mile per gallon in hot weather over cold weather. I wonder if anyone has compareable data with synthetic fluids vs mineral fluids?
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Ipc838
09-13-2015 03:27 PM
