Gearbox fault
Gearbox fault
Hello all. I started having some transmission slippage and an intermittent gearbox fault issue on cold start up that would go away on its own after I turned off the ignition and restarted. I had the transmission fluid/filter/gasket/sleeve filled/replaced. At 70,000 miles I'm sure this service was due. My mechanic said the transmission drives fine now but the car is stuck in gearbox fault mode so I only have one gear available. I disconnected the battery and ECU fuse overnight but the fault message and mode remain. Do I need to have the transmission re-flashed? The dealership here in Dallas wants 300 for this procedure alone. Does this sound right?
dmatthewman
09-30-2015 10:10 AM
