Gearbox/transmission conversion
OK, so you want to fit a late 5-speed manual gearbox, never originally fitted to the XK engine. I suspect this can be done, and there may be firms out there that do it, (for a fee). Either way, I suspect you will need a new bell housing, plus quite a few other bits, and probably a shortened or maybe lengthened propshaft, depending on the length of the gearbox. There will also be the problem of arranging the shift lever inside the car.
There is nothing insuperable in this job, just it may be expensive in relation to the benefit gained.
scooternva
20
09-27-2023 11:25 AM
