Getting Ready To Start My Engine!
Lord willen & crick don't rise, I plan to crank her after being in the Valley for 4 months.
Regardless of how it turns out, I will be forever grateful for all of your help. One of the toughest parts of approaching 80 is the loss of friends and loved ones. Between this project with your help, my sailing, friends, family & faith, it has been possible for me to keep going in spite of the losses. How uplifting you all have been! Thank you, thank you, thank you!
Now, back to business!
Unless someone sees a reason not to, I will put a trickle charger on the battery. Should I touch the battery cables together to do some sort of "reset". After closing the drain, I think refilling with coolant should be pretty staightforward. The coolant plug in the supercharger should be tightened last after the level is checked? In addition to checking sensor connections, hose clips, etc., is there anything else to look out for from your experience? Because it was leaking, I also replaced the front right air shock; hence, she is down in the front. I hope the compressor takes care of this without any further accommodation needed?
In order to observe more closely, I am planning to start her without the front bumper cover, headlamps, etc. Will this cause any problems with her brain? Is there a need to put any of the breathing apparatus over the throttle body before cranking? Assuming her dash doesn't light up like a Christmas tree, how long should I let her idle to get everything open before I drive her around the domain to remind my neighbors that they are wise to fear me? I would think 30 minutes should be enough idle time.
As always, any and all comments and suggestions are very much appreciated.
Carpe diem,
Steve S.
Carpe diem,
Steve S.
The following 2 users liked this post by 04Xjrsteve:
Big Koshka (07-30-2024),
MrWhite (07-30-2024)
Hi Steve,
the big moment is nearing, I remember how exited I was when I did the job myself...
Good Luck!
I have inserted my views into the text below.
All the best,
Thomas
All the best,
Thomas
TS: the trickle charger is only needed if you did not keep the battery charged during all this time. Also the touching of the cables to do a reset is not needed.
Please follow the correct procedure of the workshop manual for the filling and venting of the cooling system.
Regarding the replacement of the shock, hope that you did keep the car lifted until the compressor had a chance to run and do a first filling. The Bilstein instructions tell not to lower the car all the way before running the compressor, but to only lower it to a certain degree and let the compressor run, and to lower it all the way only after that. Apart from this, yes, the compressor should be able to lift the car.
TS: I had reassembled the car completely at the time before attempting to start it. Leaving off the bumper and headlamps should not pose a problem (keep the light seitch on the "off" position), but even if you get all the error warnings in the dash they should disappear after the final reassembly.
I would definitely at least reassamble all the breathing apparatus, as you call it, before starting the engine, including the air filtering, the MAF sensor, and the related hoese. Leaving something off very often leads to the engine not running properly and making you believe that something is off with the work you did.
Carpe diem,
Steve S.
Carpe diem,
Steve S.
Thanks, Thomas.
Yep, it is hard for me to believe how this has captivated me and how much anticipation there is. For a time, I traded every 2 years with little particular affection for any one car; well, maybe for a few like the 67 Healy 3000 MKIII. The only issues that I ever had with the Healy was during the times I had my cadet uniform on and drove near the nursing school. I practically needed a stick to beat them off! I'm not kidding!
The battery should be fine since it has been disconnected the entire time & I'm relieved not to be touching the cables together.
I am a bit concerned about how the car responds to the new shock. I didn't follow the recommended procedure. I seem to recall that when I replaced the left front, I encountered a similar scenario & the car took care of it. We'll see.
Best,
Steve S.
Best,
Steve S.
The following 2 users liked this post by Jaroslav Záruba:
04Xjrsteve (Yesterday),
eliotb (Yesterday)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/628x564/capture_ba80828164072e7f0dab264af0850fcbfa05f961.png)
Somehow, in following 18.50.15, I saw no mention of placing the brake vacuum tube into the brass cavity of the throttle body elbow & forgot to use my common sense and hook it up after installing the TB Elbow. Using the endoscope, I am able to see the brass ring and I'm able to move the pipe so it, too, is visible. The small hose & all other hoses and attachments are on both the TB Elbow & the TB. I haven't spent a lot of time trying to figure it out yet. But it looks like I will have to at least remove the supercharger outlet pipe.
Has anyone been successful installing the pipe without disassembling? I have nothing above the supercharger outlet pipe.
As always, your help is much appreciated. Steve S.
Mr. Jaguar designed this part with me in mind! Using a good light and finding a line of site, I was able to get that sucker installed without having to use the endoscope.
Now, will check all around & install the serpentine & SC belt, juice her up, attach the battery... & we'll see what happens!
Hi Steve,
oh my, to quote something from quite a famous film... **** happens! And I add: unfortunately!!
I did not have to try to install the brake vacuum tube without disassembling, but I believe tha you are right in saying that at least the supercharger outlet pipe has to go. Fortunatelyy, this is not that difficult.
Then I believe that you might be able to reach the fitting, maybe using some forceps. Luckily, there are no screws in this fitting, you just insert the tube into the plastic lock and you are done when you hear the click.
Good luck!
Best regards,
Thomas
Good luck!
Best regards,
Thomas
04Xjrsteve (Today)
Great on getting the booster pipe into the fitting and not having the pipe crumble upon movement. Hopefully you will be hearing the wonderful engine sound soon. One thing i remember is that the supercharger may make a funny noise for a few seconds until the oil is able to circulate to the nose bearings. Even pre oiled mine made a sound. A few seconds at idle and all was well
Main serpentine belt went on 1, 2. 3. However the SC Belt needs a gnat's *** more to make over the SC pulley lip. I've got the tensioner pulled over as hard as possible. I replaced both belts a while back; so, I would think this would go right on.
Any ideas? I can see that everything is in good order, except the bottom right looks just a bit caddywompus? I've tried to move it over down there, but it pays me no mind.
Any ideas?
Thanks and best,
Steve S.
Any ideas?
Thanks and best,
Steve S.
tobywood13
02-14-2024 08:04 AM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
