going to aftermarket rims - question
You're right, the Daimler's (in Europe, dunno for the VdP's in the US) have the TPMS.
The Daimler brand was reintroduced in 2006 to follow-up the Super V8 Portfolio 2006 X350 (only produced on a limited basis end 2005 and early 2006).
Actually the Daimler took over most of the features of the Portfolio SV8, this one being kind of proto of the Daimler, adding a few other features such as the TPMS, albeit loosing others such as the power vents.
Went in to get the winter tires on my 06 VDP, on a new set of wheels. Found out 06 Vanden Plas at least does have sensors. Now back to the drawing board and more waiting.
For the benefit of all, you can tell your vehicle has TPMS or not, by turning the ignition key, if you see the TPMS signage/light, sort of like this: (!) then your vehicle does have it. Now, I feel dumb, not knowing it myself
It's been required by law here for all cars after 2007 to have this feature so it's likely that at a certain point before then that Jaguar found it beneficial to install it in all cars since they eventually would have to due to the law.
To the OP, does your car have TPMS? Easy to tell, when you turn the key before cranking the engine you will see a symbol like this (!), my 04 XJ8 is without. Also, most TPMS based systems use a metal valve stem, not rubber. If equipped the OEM supplier was/is VDO, aftermarket replacements available from several makers including VDO. Try looking on Rock Auto .com.
