Going to have to sell my XJR
Received 9,011 Likes
General Specific - I see many many hundreds of $$$ there for checks, upgraded parts costs etc etc, that may / may not be needed.
Depending on your skill level, willingness to either do some of the work yourself with help from members here and or shop around for Indy's I'd say you could lose a big chunk of that.
I'm going to make a thread into the relevant regional section, asking for help in either resolving these issues or pointing you towards a good Indy, for a second opinion.
Thermo springs to mind as someone who may be able to help for instance, he's a guru albeit on X types but knows Jags well.
Please keep us posted.
Received 13,425 Likes
Craig,
I've seen a couple of estimates like that in the past, from shops I just walked away from and never looked back.
If I understand the estimate, they will charge you $44.95 to check for the oil leak, which is your concern, but they want to charge you another nearly $5,600.00 for parts and service that may or may not be related to your oil leak (and in some cases is very obviously not related to an oil leak).
Where, exactly, do they claim the oil is leaking? The estimate implies they claim oil is leaking is leaking from all of the following (and I may have missed something):
The front crankshaft seal
The timing cover
The engine oil cooler (not just an O-ring seal in a cooler pipe joint, but the oil cooler itself)
The camshaft covers (what they mistakenly/generically call valve covers)
The transmission pan gasket
Did you complain about a belt squeaking?
What are the symptoms of water pump failure prompting them to quote for a new pump (or are they suggesting you replace the pump preemptively since they'll have to remove all the drive belts anyway)?
What are the symptoms of harmonic damper failure prompting them to quote for a new damper?
Are they required to do an emissions and state safety check when they service a vehicle, or are these services you requested?
Did you ask them to replace the cabin microfilter and engine air filter?
I will be very curious to hear what they told you to justify this estimate.
Cheers,
Don
The timing cover
Cheers,
Don
The following 2 users liked this post by Don B:
AD2014 (12-27-2014),
general specific (12-24-2014)
Received 3,929 Likes
General, if you do not mind getting a little greasy, I am sure I can take care of most of that list in a long afternoon. Most of that sounds pretty straight forward (assuming that it really is a problem). If interested, let me know. I am probably about a 1.5 to 2 hour drive from you down in California, MD.
The following 3 users liked this post by Thermo:
Covered in length by Don, but ...
a) precisely where is it leaking? they charged 44.95 for that, so there should be an answer, unless they don't plan on looking until after getting all work authorised.
don't authorise.
b) how much oil are you losing?
Unless you are losing massive amounts of oil, the last part of the job should be the
first part of the job ...
a) completely degrease everything top and bottom, even a detailing shop should be able to do this
b) then you, not them, drive as normal until you can figure out where the
leak is, in the meantime, keep a close eye on oil level
c) when the exact leak location is identified, fix that one item
On the X350, leave the belly pan off so that you can see any leaks from below.
It is usually difficult to find an oil leak with any certainty unless you start with a
clean engine bay and underside, and then drive until it appears. Doing it in a shop
in 15 minutes with a visual results in massive shopping lists. The oil may be all
over the place, but it usually comes from one place not every place.
edit:
Oh, and if you take Thermo up on his offer, you really should start with a
clean engine bay anyways
The shop actually quoted a reasonable price for cleaning and degreasing.
Maybe you should award them that part of the job only.
edit #2:
The leak is usually forward of the bulk of the oil as the oild travels
rearwards. So the transmission pan is out.
And if the leak is minor, it could be considered an automatic rust
proofing spray system. My 20+ year old Supra had a rustfree
chassis because it lost a quart every 2000 miles and it misted
back underneath the whole car. Never dripped, just a fine
mist
don't authorise.
edit:
edit #2:
mist
Some really good useful info there Craig, I'd recommend perhaps utilising it?
As stated, I've created another thread i nthe regional section, and already Thermo who is one of our X type DIY Gurus has seen it and replied, as in the posts above.
I would seriously recommend perhaps taking him up on his offer, meeting a long standing JF member who has helped many here.......He may be able to help you save many $$$....
At the very least, he'll be able to offer good sound advice in person after looking at the car.
Hope to hear...
Hope to hear...
#28
Second, my mechanical skills are low, but my willingness to get dirty and learn is high. I'd like to talk to you more, Thermo. I'm headed out of town and won't be back for 10 days, but I'd love to talk to you more about what I might be able to do. Thanks for being so generous with your knowledge and potentially some of your time.
AD2014 (12-31-2014)
#30
A former dealer (not Jag) comments
They don't want to work on your car so they give you a shopping list to scare you off or, if you should be a complete mental case they'll willingly ream you. Dealers hate to get into finding sometimes difficult problems on older cars as they have probably been burned before by a customer with an older car thinking a simple tune-up will cure the worn valves, or some other more serious problem. When they do ONLY what the customer requests and the problem doesn't get fixed they find themselves too often on the hook for costly 'free' repairs or being faced with endless unfounded complaints from an irate customer who was too cheap to fix the real problem.
I'm not saying you're doing that, only that their policy is to avoid any such problems by practically rebuilding the car so as to have been paid hundred's (in your case thousands of dollars) in upfront money to CYA.
This is as severe a case as I've ever seen and either they're professional rip-off artists or they really don't want to work on older Jags. As a former new car dealer I've been there with customers who were able to set my service manager up but their cars were much older and much higher mileage that yours and he should have seen them coming when they first drove in.
By the way this isn't an attempt to excuse their behavior just a possible explanations.
#31
#32
I always cringe when I see shops charge inspection fees for something like a belt squeaking and then charge the exact same fee for another issue. If you are going to charge do the work. $45 is about 15-20 minutes of shop time, enough to put it on the lift and give it a fairly thorough inspection. Its a red flag that he charged you twice. If you were a returning customer, I probably would have done it for free, I agree with other posters, an oil cooler is very unlikely to fail as is a harmonic balancer. He may have just thrown in the water pump since he figured he was in the neighborhood, might want to try another shop.
Naso--Lituratus (03-08-2015)
#33
Howdy General,
You seem to have a great attitude and don't feel bad about initially wanting to punt the car, you did what any normal person would have done after getting that kind of news.
I have a general rule that I never trust a shop that charges for initial diag before really tearing into a problem. If the guy can't give you 30 minutes to either say "it's likely this or that" over the phone, or "I need to spend some real time on this to nail it down" (of which I'll gladly pay for), then there is something wrong and the BS meter goes off (in my experience). The latter being he has no clue what the problem is and is just going to start replacing stuff on your dime until its semmingly fixed.
Your experience is case and point why so many Jag's got lumped back in the day too (overheated V12's notwithstanding ;-), its really sad that honesty (and basic skills) are gone from many places.
Best of luck and keep the car!!!
Cheers.
Cheers.
#34
#35
#36
#37
#38
#40
