"Gurgling"
Check out the pic, you can see it above where the upper small diameter hose connects. The point of parking on an incline is to make the tank the highest point in the cooling system, so the car needs to be up at the front. A pair of ramps under the front wheels only would work. As meirion1 points out, do not do this with the fill cap removed or even loosened.
