Gurgling water sounds from behind the dash
Lately I've noticed liquid gurgling/bubbling sounds coming from behind the dash when I turn off the engine after a long drive (~30 miles). Is there something wrong with the coolant system or the radiator? The car appears to run normal and there are no warning lights.
Cheers,
Wolfy
Cheers,
Wolfy
Dear Panelhead
Do you know how we could unplug the drainage? Mine did the same thing for a while previously, but it has stopped now. However I noticed a fowl poo-like smell coming out of the centre vents.
I saw the other threat about the foul smell and clogged up drain pipes, and am now convinced that the bubbles and foul smell are all linked to the issue of clogged up pipes. In that case, is there's a simpler DIY way I could unplug the drain pipe?
Looking forward to forumisters' advice.
I'm surprised you had no low coolant warning. On my car I had lost about 1/2 pint and got the warning message. Are you sure you have the X350 saloon ? What year is the car ?
1964Daimler
09-09-2015 11:28 AM
