Hand Brake motor system for 2005 XJR
Hi, I'm having some intermittent errors showing whenever I pull my handbrake on my 2005 XJR, which has the original Brembo brakes. The IDS says that I may have a hand brake motor problem. I just checked the parts list on the SNG Barrett web-site and I found that there are two similar looking handbrake motor systems. C2C38667 Electronic Park Brake and C2C40572 Park Brake Assembly. Can I just ask if anyone knows if each car has two different assemblies, or is only one necessary per car and the two parts are for different model years? Is there a difference between the Brembo Brake fitted XJR and non-Brembo fitted cars? Thanks
It looks like the two numbers you have quoted one is early and the other is for a later car.
These guys in NL seem to know all about them.
Handbrake, JagParts
Fortunately I have never had a problem with my parking brake and
I was reading the other day on the internet that the complete
epb can be diagnosed electrically but you will need an auto electrician who is
familiar with them.
What DTC's do you have?
Handbrake, JagParts
familiar with them.
Handbrake, JagParts
familiar with them.
Handbrake, JagParts
familiar with them.
Below is the epb TSB which applies to your model year
http://www.jagrepair.com/images/TSB/...ng%20Brake.pdf
More info here:
https://www.google.com/search?q=c180...hrome&ie=UTF-8
More info here:
More info here:
More info here:
Robert Edwin rawle tangerinedream1
03-10-2022 05:07 PM
Cneukum
07-21-2021 12:59 PM
