Greg Front brake pads for 2004 Jaguar XJ6 3.0 SE (model for Europe )X350 XJ 2003 To 2006 Vin G00442 To G49700 also is for S Type 2002 To 2006 Vin M45255 To N52047
looks like it uses the same brake pads as the 2002 to 2006 S-type 3.0 sedan front brake pads Part number C2C23786
Year Fitted (2003 - 2005) Or VIN (G00442 - G49700) Engine 2.7 3.0 3.5 4.2 - See more at: xxhttp://www.xjkltd.co.uk/jaguar-xj-front-brake-pads-kit-c2c23786/#sthash.RUuE7zbS.dpuf
Here is another website link to the specs and performance of your specific model:
I found the Jaguar XJ X350 2003 - 2005) Or VIN (G00442 - G49700) Drivers Handbook English RHD Markets Only. It has the XJ engines that were availiable (V6 3.0, V8 3.5, V8 4.2)
I downloaded all the sections from Jaguar Topix website and assembled them into one PDF file on my dropbox account.
Here is the weblink to the PDF file: xxhttps://https://www.dropbox.com/s/f8ado3lsew0q789/xj%20x350%20drivers%20handbook%20-%20english%20rhd%20markets%20only.pdf?dl=0
Thank you! Mine is RHD (even though from Japan), so I am sure this will be much more useful than one for the V8
There are a lot of S-Types in here so If those pads will fit, I might not need to buy them online
do you know if this manual you have kindly posted is good for the 2007 model too?
Having just driven a 2004 XJ8 and a 2007 XJ8 yesterday (and buying the 2007,) I can tell you that at least the dashboard electronics have significant differences, for example, no Bluetooth in the 2004, and the 2007 touch screen doesn't exist in the 2004.
The 2004 XJ8 you drove may not have had a 2007 touch screen, but some 2004 XJ8s did have a similar touch screen. Bluetooth kits were also available from Jaguar for 2004s
Like the man in orthopedic shoes, I stand corrected!
(That's a line from Pinky and the Brain in the new Animaniacs on Hulu! Love Animaniacs!!!!)
Following up, though, my understanding is that there were significant electrical system changes in 2006, the "X356" designation, used for '06 and '07 in the US. No exterior differences.
I know the link worked because in 2016, I was able to download the following. However, I want to download the section with electronics to find the anti-theft horn & the link gives me a tribute to the late Prince Philip & jag adverts. Am I pushing the wrong buttons or is the link no longer working?
see post 57 for Corrections I had problems with weblinks
Hi Steve
You did not follow the directions in my previous posting.
I did not make a x350 workshop folder and you do not have to get an account on dropbox website to view and download the pdf files I provided.
Just click on one of the weblinks for each of the 7 sections that I provided and follow the directions in the previous posting.
here is an example of viewing the first x350 listed section:
Reason: added addition comments
Have successfully downloaded the 4 parts plus the Table of Contents for the X350. However, I haven't had success finding what I'm looking for. It seems brakes, etc. are fairly easy to find. But, I'm looking for the section that would describe replacing the Oil Filter Adapter Seals. I'm using an Imac & have the manuals in Google Drive which allows me to open in PDF or Google Documents. If I use the search options available to me, I get 4 hits for "oil filter" & none for "Oil filter Adapter". Under the heading of "Oil Pump", the closest thing I get is: "oil filter housing".
I will continue to work with it, but so far, doesn't seem to be user friendly.
