Has anyone knowledge of the E brake fault coming and going?
My 07 XJR is having an issue. The BRAKE like illuminates and I get the RED light on the dash. Then the orange light comes on sporadically and gives me a E brake fault code. I work the E brake on and off about 7-8 times and then turn off the car, start it back up and the fault light and code are gone. What is this? Please advise. Can this be sensor be removed. The E brakes work perfectly.
can you provide a download or link, battery not an issue
Battery is New Jaguar Battery so that isn't the issue. Where do I find the TSB bulletin? What does it say? Can you cut and paste the information for me please? Never mind I found the TSB but Im guessing this isn't warrantied even though they know about the issue. It is intermittent and the damn things work perfectly. Also, the second I hit the switch the brake motors come on and are locked within a half second. No, lag time what so ever
