Head light stutter 2012 XJ SWB
Old 09-12-2018 | 04:10 PM
Bubafatz's Avatar
Default Head light stutter 2012 XJ SWB
HI I have an XJ 2012 and it has developed a stutter in the head lights. For no reason they suddenly flicker or just go out. there is never a fault showing. I've noticed if I tap the indicator stalk at the bottom they tend to come on again. Any one else have this issue and maanaged to sort it ?
Old 09-13-2018 | 09:32 AM
mhamilton's Avatar
I believe you will find many threads on this forum about fail(ing) indicator stalks causing headlamp flicker. The switch assembly is a simple replacement.
Old 09-13-2018 | 10:01 AM
Partick the Cat's Avatar
You would do better to post in the X351 subform which is the XJ 2009-present. This subforum is for the X350/358 which was 2003-09.
Drossvet
10-21-2016 10:27 AM
BlownBrit
10-03-2016 04:37 PM
09-08-2007 12:08 AM
01-15-2007 01:41 PM
12-23-2006 02:15 AM
Quick Reply: Head light stutter 2012 XJ SWB
