headlamp lens pitting RESOLVED
Recently noticed this pitting on the upper edge of my headlamp lenses. Didn't realize how bad it was until today when I was on the garage floor looking up at them. Strange that it's not on the face of the lens, just the upper edge. Looks like they've been sand blasted. Hardly any on the inner lens, mostly the outer. Maybe just the way the wind currents hit the lens?
Anyway, is this common? Tried a little plastic polish, helped a little, but not much. Will something like a 3M headlamp polishing kit take these out?
Thanks,
-Michael
![Name: IMAG0375.jpg
Size: 74.4 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/156848d1501214234-headlamp-lens-pitting-resolved-imag0375.jpg)
Thanks,
-Michael
![Name: IMAG0374.jpg
Size: 86.2 KB](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/156849d1501214234-headlamp-lens-pitting-resolved-imag0374.jpg)
Michael,
Check out my "How To" in the sticky section for head lamps.
Jason
https://www.jaguarforums.com/forum/x...ng-how-120294/
Jason
Received 9,010 Likes
The following 2 users liked this post by JimC64:
mhamilton (10-05-2014),
ragman1171 (10-05-2014)
Here's a few others that might help some....
https://www.jaguarforums.com/forum/d...light+restoral
Good luck
Good luck
05XJL. My lights look the same, but I believe what caused it on my car, was detailers. The previous owner must have used detailers to get the car looking new, but they used a BUFFER to polish the finish and the buffer came down on the lens and burnt them. All four are the same--alone the top portion of each lens.
A local collision center said they will make them look like new again and even clear coat them. Guareenteed for $185.00. May try the 3m product first.
Chuck 05/XJ8L
Chuck 05/XJ8L
Just to up date my post above, I used the 3M product and the results were just like MHamiltons above. Perfect. No need for additional photo's.
The secret is a light touch and use a directed. I was so amazed, I took the stuff over to my neighbors and did his wife's Van. She was tickled ----less.
Product has enough stuuf to do 6 headlights, with enough stuff left over, that their refill kit will more then enough fill.
One note: When I purchased the kit, the kit I picked up was $39 bucks. The good salesman said he had the same kit at the counter for $17 dollars. The only difference---a half dollar size of Blue Painters tape. $22 bucks for the tape? I don't think so. Just be informed when you buy.
Chuck
05/XJ8L
Chuck
05/XJ8L
Chuck
05/XJ8L
Chuck
05/XJ8L
Worked a charm, and super results. From heavily pitted to clear as glass. Only issue I had was my Ni-Cad Batterry 18 Volt Drill ran down before I got all 4 lenses completed, and the passenger side needed to be gone back to. I only repeated the last 2 steps - the wet sand and the compound. I already had Meguiars Headlamp Preservative and it FURTHER clarified the lenses - which I would not have believed possible. I STRONGLY recommend the Meguiars if you go through all this polishing work to protect the lens at least from UV if not from the sandblasting effect of road debris. Another tip: Increase your following distance on the highway when possible and your front end won't GET sandblasted in the first place.
![Icon Dance Twist](https://www.jaguarforums.com/forum/images/smilies/icon_dance-twist.gif)
Note: Pics are from BEFORE applying preservative and it made the lens 50% clearer still. Take your time and don't rush the steps. Big Tip: If your Fog/Driving lamps are equally pitted (mine are) they should respond to the same treatment, but it will be tight quarters with the drill on those smaller lenses. I think with care I can do them, since removal looks to be a pain.
