Headlamp washer question - what stops free flow of water?
Otherwise just tell people your car is sad because you don't spend enough time together.
On these models the check valve is part of the washer jet itself. And these jets are discontinued.
Reason I know is I went through the whole draining washer fluid tank when I got my car. 3 of the 4 jets in my car were leaking and somehow the dealer kept billing the previous owner for "replacement hose" and would change a section or two of perfectly good 3/8 line, but never fix the leak. I disconnected my HL washers, plugged the line behind the bumper, and pulled the fuse for the HL washer pump, since I have no need for HL washers. If you can find new replacement jets I'd be interested to know.
Adding a check valve before the jets might be a workable solution, however. If you can find one that will stop the water flow unless pressurized by the pump.
-Michael
-Michael
Samilcar (08-27-2020)
Thanks everyone for your insights. I think I'll take the bumper off to investigate further in the next weekend or so. I think the washer jets are still available as part of a tubing assembly, maybe its sensible to replace all 4 jets at the same time although I will check the T-pieces, maybe something is lodged inside and I might be able to fix it without buying any new stuff.
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
al_roethlisberger
09-11-2015 10:04 PM
rachelstr
09-03-2015 12:59 PM
