Headlight hid issues
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
I experienced a flickering HID Bulb on the driver side days later it went out. I went and bought a new bulb and checked the fuse after i replaced the bulb and it didn't work I even took it back for another to check for defects. There is a new hid ballast AND BULB AND THE THE DRIVER SIDE HEADLIGHT IS NOT COMING ON.. HELP ......
Received 3,887 Likes
XJRPro, what year and model is your car? How are you with a multimeter? I can help you diagnose what is going on with your vehicle if you give me a little bit of information. Based on what you are describing, it is sounding like a fuse that is causing a voltage loss, causing your problems. I would say to swap the DIP beam (what us Americans call low beam) fuses and see if the problem moves side to side. If it does, then it confirms the fuse is your problem.
Let me know if you want more assistance. If you are not very familiar with a multimeter, state so and I will give you step by step instructions of what you need to do.
XJRPro (09-06-2012)
The drivers side bulb quit working, so I ordered 2 new Phillips bulbs. I changed both, now I have no low beams. I checked the fuses and the connectors and all are good. I tried to remove the whole light bucket but could not figure it out to check the main connection . If anyone has any thoughts it would be greatly appreciated. Thanks Billy
Thanks for your response George. I have been too busy to work on the car.I rcleaned the blades on the fuse for the passenger side and got it working. The driver side was still out so I bought a replacement ballast but am unable to find it on the car.
Can anyone tell me where to look and how to get there. Thanks Billy
rsa760041
23
09-25-2015 01:33 PM
2000, 2010, auto, c300, defects, headlight problems, headlights, hid, hid issues, hid problems, installation, jaguar, matic, problems, wont, work, xj8, xjr
