Headlight out!
Headlight out!
The xenon headlight just went out on the driver side LHD on my 2007 XJR X350
Can someone please give me the exact fuse location {think its under the hood but dont know what fuse} I try that first
The turn signal works ,i see some moisture behind the glas ,i went true the carwash ..
Thank you
Thank you
Take a look here for possible locations
For the driver's side low beam look in the fuse box in the engine compartment at F9 (should be 20A). Both the right and left high beam are fused at F16 which I think is also a 20A. To be clear I have an '04 XJ8 without the HID system but the manuals look to be the same for both as the only place they even mention HID is the fuse section for a 5A fuse in the cabin that controls the left & right side HID lamp leveling function.
DJ-Roy (07-14-2018)
shaffersh1
19
01-30-2017 03:04 AM
Beagle
12-04-2015 03:27 PM
Anfield Dreaming
05-04-2015 01:34 PM
jagosaurus
10-03-2012 02:51 AM
NoPaint
01-11-2009 08:39 PM
