Headligt Bulb Replacement
How does one access the right side headlight bulb? I tried opening it up and the bottom wire retainer popped off in the process of having to twist the cover to get the bulb in and I can't get the lower wire retainer back on, the access is so tight. I got the bulb in and the cover back on with the upper retainer latchedbut the lower wire retainer could not be reinstalled. There was more room on the left side and it worked okay. I am a little worried that without the lower retainer in place, the cover will leak water into the housing.
Guest
Posts: n/a
RE: Headligt Bulb Replacement
I've recently changed the headlight bulbs on both sides of my '05 XJ8 (X350). I agree that the right side might be a bit tricky to access compared to the left, but I didn't experience what you mentioned and managed to reinstall both covers securely after changing the bulbs. Was your car the '96 XJ6, or the '05 XJ8?
Guest
Posts: n/a
Hi, i have an '05 xj8 and i have a problem opening the right light cover after i loosen the retainer pin. Can anyone tell me how you do it? The authorise dealer in my country is charging me US$120 to replace the right headlight bulb only, even though i brought my own bulbs.
I have no problem replacing the left headlight bulb.
99xk8guy
06-05-2023 06:28 AM
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-03-2015 07:32 PM
