Headliner/Sunroof
I peeled mine all the way back cleaned all of the old yellow foam. Sprayed 3m adhesive on sliding part making sure not to get glue on headliner. I let that dry then used a spackle knife slowly to readhere the fabric.
Other than that you need to remove entire headliner and sunroof assymbly. and do not use any tape on headliner fabric to protect from spray glue. I used oaktag paper
Good luck
Good luck
I doubt you can do a good repair on the shade will in situ, and if the shade is failing, surely the headliner will not be far behind? I wuold do them all, not really that difficult, apart from sphincter tightening as the board bends to come out the door.
Remember you need e-torx socket if you are moving the seats.
