Headliner Wiring harness
Old 08-29-2019 | 10:48 AM
griser's Avatar
Default Headliner Wiring harness
Ok, continuing the headliner reconditioning on my car and I've run into a new snag. The wiring harness in my 2007 XJ8 is glued into the headliner board. Does the wiring harness get taken off the headliner board or can you disconnect it and leave it on?
Old 08-29-2019 | 12:05 PM
jackra_1's Avatar
I know my car is a different model/year however my harness was glued on and I simply disconnected it and left it in place when extracting the whole thing from the car
if that helps.
paydase (08-30-2019)
Old 08-29-2019 | 01:30 PM
griser's Avatar
Where was your connector located?
Old 08-29-2019 | 03:42 PM
jackra_1's Avatar
I believe there were several. All of which I could access with the headliner lowered a bit and the front A pillars taken off which with me caused a break in at least one plastic clip.
Old 08-29-2019 | 11:40 PM
griser's Avatar
Ok, thank you sir. I really appreciate the advice!
NCJagman
04-01-2015 02:24 AM
Rufus T. Firefly
05-02-2014 03:27 PM
quinnjere
04-14-2013 02:15 AM
prestone08
04-09-2013 02:31 PM
hennebear
07-27-2007 02:08 AM
Quick Reply: Headliner Wiring harness
