Heat/Defrost Issues
Hi, My heat works, but it is not real hot...I set it at 86 it is comfortable but really should be hotter I think...Also if I shut the car off leaving the heater settings untouched and come back and restart the car the rear defroster turns on with the heat but not all of the time...
With system at 86 degrees your heat output at vents should be at least 120 - 130 degrees if all is working well...
Possible heater core is partially blocked...
Don B (01-17-2017)
