Heater hose for 2005 XJR
Hey Guys, I have a slow water leak that i found on the passengers side of the engine. The hose goes from the lower steal pipe that is mounted to the side wall above the right tire, There are two hoses there. This is the lower one. It has the plastic end with the steel clip on that end and it goes up to the metal housing right by the super charger pulley near the thermostat. it connection to one of the tubes that looks like a V.
After further research I found these are the heater pipe to thermo hosing hoses. The upper is a XJR-JA-C2C-1984. Does any one know the part number for the lower hose is? This is the longer one that goes to the thermostat housing.
Members here with the same model will be able to help.
JagV8 (03-15-2017)
Hello Chris, thanks for responding. It's hard to tell. The hose looks like its one piece that goes from the steel line all the way up to the thermostat housing.But all the photos of hoses I'm getting look like hoses with multiple connections. I'll take a better look tomorrow or completely remove it. Thanks
hawaiianjag
06-08-2020 10:23 PM
