heater hose coolant leak need help
hi my mom has a xjr 05 with a coolant leak (found it leaking down the engine /trans joint). must be the hose from hell under the intake manifold/supper charger.well while taking everything apart (almost there and I do have coolant in the engine valley) I saw coolant at the heater hose firewall (car has rear climate ) 1 of the 2 fitting is broken .jaguar wants to sell the entire line but all I need is the tee and hoses (x2) has anyone fabricated or sourced these fitting -------thanks in advance
