Height sensor?
During the last oil change, I noticed the RH front height sensor had slipped out of place (not in the little notch where it should be) and slipped it back in place. After the car was back on the ground and running, the front suspension fully extended to what I would guess to be the maximum height, and the rear dropped lower than usual. So we decided to bleed all of the air out of the system hoping the car would level itself after the compressor re-charged. No such luck. The front end is still high...and rear lower than usual.
Is a visit to the dealership for a re-calibration necessary? Or would something as simple as disconnecting the battery for while "reset" everything?
Just so your aware the front end suspension is speed activated and doesn't start to lower until you get above 100mph.
If you can access a scanner that reads the Jaguar proprietary codes there's a section where you can have the system do a full empty refill scenario specifically to reprogram the system including height sensors. It's there in case a sensor gets damaged or just quits so the system can be recalibrated to a new sensor.
You'll find that most of the electronics on the Jags are not swappable without such reprograming.
